1 - 1 of 1 Posts
Vendor
For those of us that aren't able to afford a full alarm system, a disk lock is an affordable alternative to protect your pride and joy especially if you live at an apartment complex or college campus. Easy to use, the Xena XX-6 disk lock alarm simply attaches to your drilled brake rotor.
The XX-6 is available in stainless steel or yellow pictured here.
This is not yet listed on our website -- If you would like to order, please call MIKE at 866.931.6644 ext. 804. Is email more convenient? Send us a message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Designed to withstand all kinds of attacks with its high-grade mono-block alloy construction, the XX-6 is made to protect your motorcycle at an affordable price from Riders Discount.
Xena uses a ice spray-proof key barrel. It's the attention to detail that puts Xena alarms above the rest.
The XX-6 features a microprocessor in the alarm module with motion and shock sensing capabilities powered by a long-life lithium battery. If the XX-6 senses motion or any shock to the unit while armed, it will activate it's deafening 120dB siren.
6mm pin with a 7mm gap size and a 42mm gap between the pin and lock body, this is ideal for scooters and motorcycles with disk brakes.
Included with the disk lock are 3 keys and 1 alarm module removal key. Replacement lithium batteries are also available and sold separately.
If you need a bit more gap space, ask us about the XX15 disk lock which offers similar features but with a heavy duty 14mm carbide-reinforced locking pin.
1 - 1 of 1 Posts
