I am having trouble understanding the injector balance map.
Every explanation I have read says that it is the balance between the upper and lower injectors. OK.
And from what I can gather a 50/50 split is what you want for high RPM performance. OK.
BUT the map cells are from 0 - 100
So my stock map shows 100 all the way up to 11500 rpm then backs down to 80 as the RPMs climb.
What does it mean?
Is this the upper injector backing off to 80?
Is this the lower injector backing off to 80?
I cannot find a decent explanation.
EDIT I found the answer. There is a Group drop down that selects the upper and lower. Woolich helped me with it.
What does it mean?
