1 - 3 of 3 Posts
Does anyone know what the swing arm nut size is ? I would like to go out and buy the right sized ratchet to do my first chain adjustment
Thanks
Welcome.You don't remove the swingarm nut.You loosen the axle pinch bolts at the rear.Your adjuster is in the pocket under the seat.Hook wrench.Silver.Use with the extension in the tool pouch.When tightening,you go from the far right bolt to the left bolt and back again.Look in the periodic maintenance schedule in your service manual.You also need to make sure there's no gap between the adjuster and the swingarm when tightening.It's all in there.Page 2-43.
1 - 3 of 3 Posts
