1 - 1 of 1 Posts
Vendor
Used by motocross, supercross, road and flat track racing champions, Vortex's motorcycle accessories are some of the best in the industry. The Vortex ST901 Rear Race Stand is a compact option that allows you to work on your motorcycle without the stand getting in the way. Made out of heavy duty steel and laser cut spool lift plates, this stand will be able to effortlessly hold the weight of your bike.
The special pivot angle is designed for easy lifting. You can adjust the width of the Vortex ST901 to fit your bike perfectly.
Non-Spool Conversion Hardware is available for this stand, but not included. Please note that these adapters are compatible with the ST901 only, and are sold separately from the race stand. The adapters are rubber coated to help prevent damage to the swingarm, and are easy to install.
MSRP $99.95
Not yet listed on our website, you can order your Vortex ST901 Rear Race Stand and Conversion Pads by calling MIKE at 866.931.6644 ext. 804 or by sending us a private message through this forum. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
1 - 1 of 1 Posts
