1 - 20 of 20 Posts
I have a new H2 and am thinking about buying a Vandemon exhaust, the Akrapovic that came free with the bike is very quiet even with the baffle removed and i'm disappointed with the noise, my previous bike was a Tuono Factory and although that was a different configeration engine wise the H2 sounds very muted, any thoughts on wether its worth spending the best part of £1800 which is a lot of money on a Vandemon? also will it throw up an engine check light and what about passing a UK `MOT test with the cat removed etc etc, rgds Stuart.
Just about anything after market will not pass. There is a label on the LH frame giving it the factory certified db's. Do what most guys do, go back to original for your MOT.
With the heat from an H2 most after market mufflers have a shorter life if you ride the bike like you stole it. I have a muffler that cost NZ$1800 and have had to repair the primary baffle and replace the burnt out packing. So that's what the H2 can do to Titanium.
The only good thing I can say about a loud exhausts on an H2 is the quick shifter sounds impressive up or down, apart from that it's a pain in the butt for longish rides.
Ive seen slightly used brocks full exhausts with slashcut muffler, carbon black muffler, and alien heads for 800$ area "usa dollar". Or new for a little more and they are extremely loud and snappy in shift. Also the packing and metal honeycomb part is extremely thick and robust. Ive never heard of a brocks melting down or spitting honeycomb ever unlike a few other top brands. But the vandemon mimicks the h2r so everyone seems to go for it.
You won't be disappointed with a lack of noise from the vandemon, guaranteed. At any revs/load it sounds great,a constant reminder your on a high performance and special machine. No outwardly visible signs of degradation though it has blued up markedly but nicely to my eye, in a thousand miles.
I bought the Akrapovic race system from Kawasaki for my H2. It's titanium rather than steel, a larger diameter right through from the headers to the muffler (you will need a bigger diameter muffler too) and it has no catalyst. It does have the threaded boss for the lambda sensor and fits straight on with a rather nice carbon fibre hanger. You save at least 10kg in weight.
I run at Straightliners meetings doing standing miles and there's a noise limit. Mine measures between 95 and 98dB from meeting to meeting with the baffle out. The bike has done many full throttle runs over the last few seasons with no problems like on the Vandemon. The sound is quite sporty without being annoying, obviously this depends on how you ride.
Actually you don’t need the bigger muffler, I bought the same system as you Bob complete with the wider diameter headers but made to fit the road legal Akra supplied with the UK H2.
As you can see from the image the pipe exit is crimped to fit but you need to order the correct part, Calsport can help with this, they’re good guys.
Agree that it’s has fantastic build quality, perfect fit with lambda & it has plenty of character but doesn’t make your ears bleed.
Also if you insert the baffle it will go straight through a UK MOT.
The Vandemon obviously looks better but the sheer noise and grief with MOT (and talk of failures) would put me off.
TBF there is plenty of choice with Austin, Akra, Vandemon, Brock’s & Yoshi to name a few
The 2019 standard system (complete with cat) is louder than the standard system on my 2016 but I believe the silencer is different and the system is visibly different from the headers down.
I’ve had/have Brock’s on Busa, ZX14R, the Vandemon that’s on my H2 is amazing, quality welds with good penetration, fit finish is awesome, the sound without the baffle is so deep, and throaty.
I'm have decided to go for the Vandemon for my new 19 model H2 and went to the see the mechanic today to book it in and I suggested to him that it would need a power commander which he agreed, he rang me later and apparently they haven't produced one yet for the 19 model, my question is, is it ok to fit one without a power commander? btw he is going to fit a servo eliminator.
Loud exhaust will be an advisory on not a fail,, though the tester may well want to see the original.
This from a major Kawasaki dealer service receptionist two days ago.
When your dealing with emissions and getting a reasonable price, picking an exhaust is tough. I bought a Vandemon and feel like it was worth it. I haven't had any issues with 3000 miles. The engine code is solved with ECU flash. My second choice would have been Austin Racing. Its extremely expensive here in the USA. Cheapest I found for a fully system was about 4,500.00 USD. Way to much. I have an Akrapovich system on my R1 and love it. Fits the bike perfectly. Not so much on the H2. Just my opinion but I'm sure you won't be disappointed. They make excellent quality stuff 👍👍
Austin racing looks good but had failure in the first baffle due to not handling the heat, you can see the pipe went blue. Easy fix, about $10.
It's deep not raspy? I'm tossing up between a full Alien head or Vandemon
What failed ? I'm thinking of this pipe for mine, has it got two baffles? Might be too quiet
The first baffle, got so hot the baffle flanges that are held tight in compression by the springs went soft and allowed the the gasses to get directly into the packing burning it out (gone). Ended up rattling and loud so I fitted a SS hose clip to take up the slack as well as winding boiler rope around the perforated pipe so it was full and tight agaist the failed flanges, no trouble since.
No, the actuator valve is working as I like what it does.
1 - 20 of 20 Posts
