sure is a thirsty beast
not a lot of range if your on it
There is no fuel level indicator apart from the low fuel light. I simply reset the 'fuel used' readout each time I fill with fuel - I know how much fuel the tank takes, the readout tells me how much I have used, so I can quickly work out how much I have left !Maybe someone here could help me with just HOW to read this fuel guage deal.I fill her up....and on the display it shows a number of how many gallons used during a ride...however....is there a way to see where it's at at any given time?Like a display or something?Maybe I've just missed where it is or whatever.Any fuel level indicators?Besides the yellow 'gas pump' icon?
Pebs said..."I simply reset the 'fuel used' readout each time I fill with fuel "There is no fuel level indicator apart from the low fuel light. I simply reset the 'fuel used' readout each time I fill with fuel - I know how much fuel the tank takes, the readout tells me how much I have used, so I can quickly work out how much I have left !
Press the 'down' button on the left side switchgear until the 'fuel used' readout appears - then hold the down button for two or three seconds and it will reset to zero.Pebs said..."I simply reset the 'fuel used' readout each time I fill with fuel "
Okay...so how do you reset that display?And thanks....I'll be doing that.
It's as good as a normal fuel gauge. Just reads from zero to 17 litres instead of the other way. The main difference being you have to brim the tank and reset it for it to be meaningful. I tend to use one of the trip meters which I zero when I fill the tank.There is no fuel level indicator apart from the low fuel light. I simply reset the 'fuel used' readout each time I fill with fuel - I know how much fuel the tank takes, the readout tells me how much I have used, so I can quickly work out how much I have left !
