Thermoelectric Boost Cooling & Charging System
504 Views 5 Replies 2 Participants Last post by  GRUNTMAX
11
This should eliminate any requirement for water mist injection.Thermoelectric_Boost_Cooling_&_Charging_System.pdf
Wheel Tire Motor vehicle Automotive tire Tread
Automotive tire Tire Hood Motor vehicle Tread
Motor vehicle Car Automotive tire Vehicle Automotive exterior
Automotive tire Wood Motor vehicle Gas Engineering
Speedometer Motor vehicle Odometer Light Gauge
Font Screenshot Parallel Number Rectangle
Wood Gas Natural material Metal Fashion accessory
Revolver Bumper Electric blue Rectangle Automotive exterior
See less See more
1 - 6 of 6 Posts
10
4 x Voltage Boosters
Circuit component Electrical wiring Passive circuit component Aluminum can Electronic component
Installing the TECs to Extreme Creations external air to water intercooler;
Mousetrap Font Gas Rectangle Carmine
Liquid Fluid Tin Drink Cylinder
Tire Motor vehicle Automotive tire Automotive design Tread
Automotive tire Hood Motor vehicle Automotive lighting Grille
Automotive lighting Automotive tire Gas Electrical wiring Grille
Tire Automotive tire Hood Automotive lighting Motor vehicle
Grey Composite material Gas Pattern Metal
Liquid Bottle Fluid Gas Drink
Wood Gas Composite material Grille Automotive tire
See less See more
Hi, read the article and seems interesting. Trying to understand more.
The intercooler already lowers the temperature, but what additionally does the thermoelectric do?
Uses the heat from exhaust to produce voltage for the batts?
The TECs (Thermoelectric Cooling devices) peltier modules are fitted to further lower the temp another 5 degrees C.
The TEGs (Thermoelectric Generators) peltier modules produce DC power to feed into the 2 x Batteries wired in parallel.
The extra power generated is used to feed into the TECs mounted to the downstream end of the external air to water intercooler when the rpm exceeds 4,000rpm. I set the external air to water cooler up with different TECs starting with lowerage amperage draw & only 2 x TECs, then on 3rd prototype increased to 4 TECs for maximum amperage draw.
Have attached 1 pdf of TECs I ended up using & 1 pdf of TEGs used on exhaust.
Now, no need, even if I did need it for Water/Methanol mist injection & works all day with no need to recharge batteries.
I initially thought about patenting, however, all required components are commercially available.
If i understand this correctly (give me some rope), the heat from the exhaust is used to generate power and is stored in the batts, and at 4krpm its discharged to produce extra cooling to the intercooler radiator thus lowering the air temps by another 5c?
Can this be done at the tank base to lower fuel temps?
1) Your "understanding" is correct, however, removes heat from "external air to water intercooler".
2) No. ,,,, only trying to remove heat from compressed boost charge air from inside plenum chamber.
1 - 6 of 6 Posts
