Just removed the fuel one off the tank with a little heat from a heat gun.
Worked slick!![]()
WD40 is the best cleaner around...just don't expect it to lubricate things>WD40 is good for getting adhesive residue off, also. Years ago we were putting up a chandelier that had tons of glass parts with tags on them. Tried ammonia, thinner, nothing worked and then the glass guy said to use WD40, problem solved.
you mean you're not supposed to use it on your chain?WD40 is the best cleaner around...just don't expect it to lubricate things>![]()
Only if you are trying to get a sticky label off.you mean you're not supposed to use it on your chain?![]()
