1 - 4 of 4 Posts
I've just put a Sprint Filter P08 on the H2 and wow, it make it super lean.
I knew it was going to breathe more and the visual difference is chalk and cheese side by side but after adding 25% more fuel and going for a ride it's still lean.
How much fuel did you add when you installed it?
ayjayef,
If you have no other mods to the stock bike, the addition of the P08 will simply bring the AFR to a 'less excessively rich' mixture, primarily at high revs.
If your bike was previously mapped, the addition of the P08 will represent an AFR which is 0.1-0.2 "leaner", which is barely noticeable on the dyno and not possible to notice with an 'ass dyno'.
If your bike runs considerably/noticeably different after the addition of the P08 filter... you have something wrong. Please reinspect the filter area to make sure that it is properly sealed/seated. Also make sure you didn't accidently pinch wires in the assembly (we have seen this several times with PCV wires).
Please contact [email protected] for additional info. Or use our live chat.
Brocks Performance
1 - 4 of 4 Posts
