1 - 1 of 1 Posts
Vendor
DOT and ECE approved and under $80, the Speed and Strength SS1300 Take All helmet is in stock and ready to ship from Riders Discount today!
Available in the white/green graphic shown here.
The Speed and Strength SS1300 Take All helmet is available to purchase through our website. If you need help placing your order, or have any questions about the product, feel free to give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Worried about ordering the wrong size? Don't worry, Riders Discount has an easy returns and exchanges policy.
The Speed and Strength SS1300 helmet uses their lightweight Thermo-Poly Alloy shell, which is aerodynamically shaped to quietly cut through the air and prevent lifting at speed. It also channels air into the Airstrike ventilation system through two vents on top of the head and one below the face shield; all of which are fully adjustable. Any air that enters the helmet needs a place to go, so exhaust vents have been strategically placed at the rear. They use the area of low pressure that forms behind the helmet while you are in motion to pull warm, moist air away from your head. No matter how effective the ventilation is, the unfortunate truth is that everyone sweats and this can build up. Speed & Strength uses their Cool Core liner to help keep things fresh when this inevitability becomes an issue. The plush lining wicks moisture away from your scalp in order to keep you dry and can be washed when necessary.
Available today from Riders Discount, order your Speed and Strength SS1300 Take All helmet on our website or contact us if you need help placing your order.
1 - 1 of 1 Posts
