1 - 4 of 4 Posts
Vendor
Invisible from the outside, the Sena 10U Communication System is a built-in system that allows you to talk with up to four people within 1.6 kilometers thanks to Bluetooth Technology. You can also listen to your favorite radio station by activating the integrated programmable FM tuner.
The Bluetooth Handlebar Remote is easy to use with gloves, allowing you to focus on the road rather than the device. The 10U is equipped with special noise control that blocks out distracting sounds such as wind, while still allowing you to be aware of your surroundings.
MSRP$299.00
The Sena is easy to install, so you don't have to send your helmet out. The Sena 10U is available for the following helmets:
Shoei GT-AIR
Shoei Neotec
Schuberth C3/C3 PRO
All Arai Full Faced Helmets
Pictured above is the Sena 10C, an external communication system. As you can see, the external system looks much different than the Sena 10U, which is pictured below.
Pictured above is the Sena 10U installed on a Shoei Borealis Neotec
If you have any questions about the product or would like to place an order, feel free to give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Vendor
Discussion Starter · #2 ·
One of the best qualities of the Sena 10U is the easy installation process. We will walk you through how to install the device on a Shoei Neotec.
To begin the installation, remove the Neotec's ear and cheek pads. Next, install the snap holder and speakers by inserting the speaker into the designated cutout on the Neotec (see second image below). Repeat on the opposite side.
To install the battery, insert the battery piece between the shell and interior, as shown in the image directly below.
To insert the antenna, insert the straight end between the shell and interior on the side of the helmet (see second image below).
Lastly, to insert the microphone piece, simply insert the part with the controls between the shell and interior on the opposite side of the antenna, as shown below.
Now you are ready to enjoy your Sena 10U and Shoei Neotech Borealis Helmet together.
The camera you can attach to the side looks pretty cool.
I get nervous about wearing headphones while riding (or driving) because it cuts out one of your senses. It's important to be able to hear what's going on around you.
Vendor
Both great options to choose from.
1 - 4 of 4 Posts
