1 - 4 of 4 Posts
I've got a ram-mount. Not too happy about it. It's a bit loose...
Got the same setup on mine and it's fine - I think the ram mount fitting is available to suit different size holes in the headstock ? If you get one thats too small it may not tighten up enough to be secure ?
@DeRox
Take it back out and start again. Its all about the tightening procedure and how much you cut off of the bottom rubber part to make it flare out. Try and take it out and hold it and tighten it by hand, then put it back in, and tighten more.
1 - 4 of 4 Posts
