What brands of the above have you guys found to be reliable?
.... also what spark plug gap do you guys recommend for the stage 2 gears?
Thanks!
Stick with the oem plug, and gap them accordingly.
Make sure when you do the leak down test, that the throttle blades are open or you will get skewed results. I thought you already established that your head gasket was blown though??
Compression or leakdown test may not find a head gasket that leaks compression into the water galleries when running esp if loaded hard, best try and find a garage or service agent with a combustion gas tester for the cooling system
I am taking it to CMP to have them deal with it.
Jeremy said he would let me borrow your H2 while he was diagnosing mine :)
.... just kidding.
