Okay...I'm gonna replace my rear sprocket here this week.I'm looking at the diagrams for this.
It says in there...to use a 35mm 12 point socket to remove the 'axle nut'.
I bought a 35 mm 12 point 1/2 inch drive socket.
Can someone explain to me HOW to fit this ANYWHERE on there?I looked twice at the axle.This socket is WAY too small(if they mean to put it on that larger nut).I didn't take anything off yet.The book shows removing the clip ring.Okay.Is there something UNDER that ring I'm not seeing?I have a 24mm allen that fits in the axle there.Use it to remove the front axle.It fits the back also.I have two identical 'allens" for both sides of the axles.
WHERE does a 35mm 12 point figure into this?
Thanks all....
That 'nut'(job) on there is WELL larger than a 35mm.You guys know how that front axle has that nut on the left side,and you turn that out (off the axle)...does this rear have the same type of 'nut' on there?It doesn't look like that large 12 point on there is gonna allow the coupling to pull away.
Anyone?Anyone at all
Thanks all....
