1 - 3 of 3 Posts
Hi everyone,
So I finally got round to setting the suspension sag on the h2, problem is I couldn't achevie the recommended starting point of 30mm front and rear.
I weigh 189lbs and could only reach 41mm in the front forks with 14 clicks of preload which is nearly at maximum hard setting and the same goes for the rear I managed 42mm with 14 clicks again nearly at maximum. I used the racetech method of measurement.
Has anyone else had a similar issue or could possible give me some advise on why I can't reach these numbers or how I could do something different to achieve them.
Also it's the 2017 model I have with the ohlins ttx36 shock I found it really hard to hear/feel clicks on the remote adjuster has anyone had the same problem?
Thanks in advance.
1 - 3 of 3 Posts
