1 - 3 of 3 Posts
Just received my Pingel Kill Switch and the instructions say to splice existing on/off switch wire. Has anyone hooked one of these up? Do they mean the ignition switch or the handlebar mount stop switch? Is there a clean way to do this?
The kill switch you bought is somewhat of a generic model. It will fit, but it will take some grinding to get it on if you mount it on the right handlebar. I had to loosen the throttle and the brake switch and spread them a bit to get the switch in. I still had to grind on the Pingel a bit too. I spliced into the kill switch wiring and used a bit of tape and shrink wrap to tidy it up. Works great and passes tech! PM me if you need to talk about it.
Ed
Mounted switch to my left handle bar because there is more room on that side. Still had to shave the switch to keep the clutch handle and clutch reservoir in the original location. Cut the brown wire for the ignition feed at the 15 amp #5 fuse behind the #1 fuse block and wired the switch inline.
1 - 3 of 3 Posts
