1 - 15 of 15 Posts
obviously you won't be seeing any track time, or if you do you'll be in for a rude awakening.
I never even understood the dark windshields on sportbikes, why wouldn't you want to see where you are going..
Reactions: BobC and h2madness!
Guess I hadn’t thought about that. I’ll have to take her out today and see where my sight lines are.
So it looks like Bob is running an after market screen that comes up considerably higher. The stock screen that I’m using is really low. I’m a full tuck I can still see pretty well. Granted, it’s not like it should be. Thanks for the tip, guys
H2 madness.....you missed a pun. You could've wrote "say it paint so" lmao matty get a tinted double bubble you will need it once over certain speed.....cheap enough also
NOLA is our smart ass moderator
Reactions: NOLA
Yes, it's a Zero Gravity Corsa.
In the attached thumbnail the top one is the stock screen and the lower is the Zero Gravity Corsa. It does make a difference in LSR.
Zero Gravity also make a DB screen but the raised portion is much narrower. The Corsa is better for my application.
1 - 15 of 15 Posts
