1 - 20 of 29 Posts
I have a 2016 H2 with an Extreme Creations Intercooler, stage 3 gears and head / cam work, every 4 or 5 high speed runs it pukes oil all over the place even if the oil level is only half full, does anyone know where i could install an oil catch can to vent the crankcase and solve this issue?
Had anyone vented directly into the exhaust after the O2 sensor, it seems a few boosted car guys have done this with success and would save me the huge headache of trying to find a place for the catch can on the H2 which has no space for anything!
Thx.
Does it accumulate for the non puke runs and only sometimes shows or is it only sometimes that it does it at all
Thinking its either detonation unsettling the rings sometimes or you need to do a leakdown to see if you have any damage
Discussion Starter #3
Only does it on top speed runs of one mile, normal riding no issues, leak down test shows motor is fine.
The last time it filled the corners of the extreme creations intercooler where the connectors are and the oil worked down the threads and pooled in the top of the crankcase.
This time it blew out the blow of valve.
Still sounds like detonation , rings should seal better under higher pressure
my turbo bikes running up to 32 psi blow out nothing unless there is something else going on like detonation, over full or motor damage
and not much reference from others with puking problems
cant comment about my H2 for another week , its a shed and dyno queen until i hit the salt next week
Discussion Starter #5 (Edited)
Motor had a full rebuild 1000 miles ago, new head, cases, pistons, etc....
No one else is going 238 mph GPS as far as i am aware.
If i keep it under 230 mph GPS no issues.
Discussion Starter #6
I look forward to your results, i have been waiting a long time for this:)
Ok, so 8 mph is a large hp increase at that speed , maybe even change in throttle position , not so much rpm but psi could vary with tps
Same setup as before the motor build ? and what let go ?
About as long as i have been waiting ;) when i first started the build page
As long as we get the meeting done
Government has recommended banning gatherings of more than 500 people, so DLRA is considering there position now
in some respects its not like a spectator sport with people jammed into close seating , more like a community with the exception being cafeteria style eating and limited amenities
guess we will know in a few days meanwhile i keep finishing the bikes
Discussion Starter #8
Everything is the same as before ... as i continue my disassembly the intercooler is full of oil, i am about to check the plugs and do a leak down test.
My mechanic thinks it could be "piston ring flutter" because even though it has stage 3 gears, which produce 28 psi, at higher rpm due to the CFM limits of the supercharger it drops to 20 psi.
The motor is pulling 13 8xx rpm with 19 front and 37 rear and 60 aspect ratio rear tire so i am also getting wheel spin on a stock swing arm.
Let me know how things progress on your end.
Have you run the high speeds with no air filter ?
just struck me that the filter could be restrictive enough when you have a larger air demand of the stg 3 gears to have reduced atmospheric pressure post filter
28 psi at 100% throttle ? or are you not getting it wide open at high rpm in lower gears ,
the more i see logs of these bikes the more interesting the dynamics
also some weird stuff going on in the OEM ecu
if you need more info on that give Guhl a call
Discussion Starter #12
I have not tried without the air filter, i use the Sprint Race Filter.
My mechanic told me about the super charger's dropping the psi from 28 psi to 20 psi at high rpm. I have not gone WOT in any gear other than 6th gear, since the last time i did it wheelied in 5th gear at WOT well above 200 mph gps with me flat on the tank:eek:
Big one we are testing this week, other 2 i have data from
Custom wheels , housings need modifying, bearing section needs a minor upgrade , also rebalance of the rotating assembly
Discussion Starter #14
Recent log file data.
rpm -13742
cylinder -1- fuel percentage- 85.63
cylinder -2 - fuel percentage- 89.44
cylinder - 3 fuel percentage - 87.99
cylinder-4-fuel percentage- 95.01
afr - 12.4803
237 mph gps - rear tire spinning.
I am shocked at the variance from cylinder 1 to cylinder 4 regarding fuel percentage!
hmmm, what exactly is fuel % a % of , total available fuel ??
Anyhow, if we make some assumptions and work on the numbers , the average is 89.5 for an average A/F of 12.48
and as a rough generalisation when i am tuning a 10% fuel change will give a 1.0 a/f ratio change (if the fuel % numbers are not leading me on a wild goose chase)
then cyl 1 is about 12.0
cyl 2 pretty much the average 12.4
cyl 3 about 12.3
and cyl 4 about 13.0
thats starting to get very lean for boosted application,
What happened when you hurt the motor and which cylinders were affected most ?
can you trim individual cylinders , and does the log include TPS and PSI figures
Discussion Starter #17
cyl 3 about 12.3
The TPS log is 100%, no PSI figures :(
The original motor was rebuilt by Kawasaki under warranty due to a head gasket failure.... power upgrades were done AFTER the motor was rebuilt.
OzBooster
Can joe blow of the street, go to the store and purchase one ?
You should start posting on your build thread again ?
Build thread yes probably, got pissed at photobucket and pretty much abandoned the thread
Not an off the shelf part , i get these ordered in and modified to suit ,also mods needed to the bearing section
I have another of the 84 mm in stock, but these are untested as yet , several of the 76mm and 78mm , also some of the original style 6+6 in 78mm
Biggest question on the 84mm is how long can the plantarys stand the increased load, already seen variations in the fit of the gears due to age on the ones i have handled
also will the bigger wheel stand the rpm of the stg 3 or 4 gearing and how much psi will it make
both the 76 and 78mm wheels can do 30 psi with stg 3 gears with H2R cams
1 - 20 of 29 Posts
