A highly sophisticated electronic system based on actual Kawasaki racing experience that’s designed to maximize forward motion by allowing racers to ride closer to the edge of traction
• The system crunches a wide range of data, including throttle position, wheel speed, engine rpm, wheel slippage and acceleration, with help from a speed sensor fitted to each wheel
• The quickest acceleration requires a certain amount of wheel slippage, so to optimize traction, S-KTRC actually allows for optimum wheelspin
• Using complex analysis, the system is able to predict when traction conditions are about to become unfavorable. By acting before slippage exceeds the range for optimal traction, the system can quickly and smoothly reduce power slightly so the wheel regains traction
• S-KTRC confirms conditions 200 times per second and governs ignition, which allows extremely quick response to changing conditions
• Riders can choose between three operational modes, depending on skill level and conditions
• A level meter on the LCD instrument panel displays how much electronic intervention the system is providing, in real time
