1 - 1 of 1 Posts
Vendor
Available at Riders Discount, the Mobius X8 knee brace is the very same knee brace worn and developed by motocross and supercross champion, Ryan Villopoto. Most notable about the Mobius X8 is the use of a continuous cable routing system that allows you to custom fit the knee brace for an unparalleled system of support and protection.
The Mobius X8 knee brace is available to purchase through our website. If you need help placing your order, or have any questions about the product, feel free to give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
To determine your size, measure 6" up from the center of your knee cap and then measure the circumference of your thigh at that point.
  • Small: 16"-18" (40cm-46cm)
  • Medium: 18"-20" (46cm-50cm)
  • Large: 20"-22" (50cm-56cm)
Worried about ordering the wrong size? Don't worry, Riders Discount has an easy returns and exchanges policy.
A result of seven years of research, development, and testing, the Mobius X8 knee brace is best on the market today. Knee injuries continue to be some of the most common and repeated injuries in motorsports and the engineers at Mobius are determined to find a solution to this problem. With the Mobius X8, they're definitely headed in the right direction.
A design unlike any other knee brace, the X8 uses a CCRS (Continuous Cable Routing System). It is a continuous cable loop in a figure-eight configuration that loops around the knee joint. The CCRS tightens when forces are applied to the knee joint. In turn, the brace shells tighten also, to keep the knee firmly in place. Adjustable with a large dial on top of the thigh, the dial is large enough to turn easily even if worn under pants.
Two colors available on the Mobius X8 knee brace, storm grey and crimson as shown here or white and acid yellow. If you need assistance placing your order through our website, give us a call or send us an email and we will gladly help.
1 - 1 of 1 Posts
