Hip protection is one of the areas that are lacking in suits or riding pants. Protect one of the most vital joints in your body by purchasing the KNOX Trooper armored shorts from Riders Discount today!
The KNOX Trooper V14 armored shorts are available to purchase through our website. Retailing at $89.95, if you need help placing your order, or have any questions about the product, feel free to give MIKE a call at 866.931.6644 ext. 804. Is email more convenient? Send us a private message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Sizing was true to size based on the size chart. Basically, just order the size you normally get for your boxers/briefs and that should work perfectly. Still worried about ordering the wrong size? Don't worry, Riders Discount has an easy returns and exchanges policy.
Designed and manufactured in Britain by KNOX, these are made from a breathable lycra material that wicks moisture quickly and keeps you dry under extreme riding conditions. Shipped with a removable chamois pad, these can also be worn for cycling or mountain biking adventures. Along the bottom of the shorts are PE embossed padding for additional thigh protection.
The CE approved KNOX Flexiform+ hip protectors have a memory foam property so that the conform and flex to your particular body shape. In the back is a removable coccyx pad fitted as standard to protect your tailbone.
Along the hem is a silicone gripper to hold the shorts in position and stop them from slipping up your leg.
Available today from Riders Discount, these KNOX Trooper armored shorts can be yours by adding them to your shopping cart or contacting us today!
