1 - 10 of 10 Posts
Does any one know the make of the exhust on the h2r i thought it was a broks but i contacted them and they said they based there exhust off the h2rs system but its not the same another one ive seen is vandemon but cant seem to find much on the vandemon any one help me out here
Kawasaki probably do the original exhaust in house ,
Vandemon are a very good replacement, and the owner is great about replying to questions
Vandemon performance is the web site
Discussion Starter #3
Is it possible to fit it to an standard exhust the end can with maybe the help of an exhusts specialist had the pipe decatted and had a project sc on but its way to loud and just had a accident so needs replacing that part?
What exhaust is this?
It's the stock header/ cat exhaust with a ZX-10 can. Black Heat shielding is ZX-10 and Frankensteined original H2. Can/muffler weights under 4lbs and is ti. the cost was around $100 essentially new taken of a new bike. Stock can approx 16lbs. Slightly more aggressive exhaust note but not boy racer lol
You'll find a Cat replacement section on the UK ebay. Then you can bung any good slip on exhaust stack you want. I reckon the Kwaka Headers will be good enough.
Good idea... Did you re-map? If not, any issues? Back-firing on decel, loss of power, ect?
1 - 10 of 10 Posts
