1 - 2 of 2 Posts
Hello i have 2016 kawasaki h2 ,facing a problem my bike meter is not stable on standing mode speed meter fluctuates from 1to 5km speed any queres thnks
I guess you are talking about speedometer? The speed sensor is from the rear wheel and reads the pulses so if your not moving and it gives a reading then there is electrical noise in the connection. Does it change when revs are held steady or worse when the engine reves are changed? Follow the wiring and check all the plugs, if not that then the sensor might be faulty or just dirty.
1 - 2 of 2 Posts
