1 - 7 of 7 Posts
I noticed that the bike has a humming sound when the ignition switch is on, and not running. I am not talking about the steering damper. Any idea of what that is? I'm sure it is normal, just curious.
I don't believe it is the fuel pump. It is a sound that is continuous, not momentary as when the fuel pump pressurizes the line.
The fuel pump runs for just a few seconds then shuts off if you don't start the engine. If you open and close the throttle you can hear it working the throttle plates.
mines has the same... its like the fuel pump but it never stops (at least not in 1-2 minutes)... maybe the fuel pump system has no release feature? it just turn and run?
1 - 7 of 7 Posts
