1 - 4 of 4 Posts
Hi Guys,
does anyone know where the up/down headlight adjustment is located on the H2 ?
It wasn't set correct from factory when bought new and is pointing way too high up
Thanks,
Pete
Okay...if you look facing forward on the bike,you see the headlamp assembly in there?Now turn the bars to the extreme right(or left).Shine a flashlight down on the lower left side of the headlamp vanes.See that silver large flat BOLT(looks like about a 5mm or 6. with the teeth on the flange?)NOT the phillips just above it)That's your vertical adjuster.Should be able to get an extension in there.Left inner cover MAY have to be removed to fit an extension...IDK.With the bars centered.
1 - 4 of 4 Posts
