Hi all. I am going to fit bar end mirrors to the H2 but I'm not sure what the handle bar INSIDE diameter is for the proper adapter. I also don't have an Allen key big enough yet to remove the stock bar end covers so I can measure it. If anyone has gotten bar end mirrors or currently has the handle bars apart, do you know the inside bar diameter? Cheers
Inner diameter is 16 mm in the threaded portion, but it steps up to a smaller diameter at a certain point. With my bar ends I had to modify and remove some of the length from the adapters in order to get it to fit.
Do you have any pictures of the finished look?
I don't have any great photos and might not be able to snap new ones for a few days. Here's what I have offhand:
(I need MORE MIRRORS :p)
Since these are like lever guards with mirrors stuck on the end, I had to space them out to let the levers have enough room. Conveniently, the stock bar ends were basically the right size, so I had them drilled out to the diameter of the bar end adapters. I love these to death, since it puts the mirror further forward than a standard bar end the visibility is great. I had CRG Arrows on my H2 before and didn't like how far back and down I had to look to check the mirrors.
Geez what happens when you filter through traffic? Good luck with those things ;)
