1 - 8 of 8 Posts
hello
Is anyone has winglets install for street use ?
I ordered mine but im not sure what to do and i would like to know what you have done for replacing mirrors and adding turn signal..
I saw someone with a back camera and some with bar end mirrors...
thanks for the help
I did.I installed a set of amber led strips to the lower airfoils just under the intakes.Actually,installed on the lower underside of the intakes.They work great.Installed a 2" round mirror on the left bar end.Also works great.
Great do you have any picture ?
just clean the surface,apply some lightly soapy solution(on surface and decal sticking side),and place peeled sticker on there,using a credit card to get any bubbles out.Working from center to edge,gently.Position decal how you want it.if it starts sticking add some solution or lift back off and reposition.Use card again lightly to remove excess fluid from underneath.Use a soft towel to pat and remove edge liquid.DO NOT touch the underside of the decal.Peel the backing paper off a small amount where you'll attach it to the surface.spray decal and surface,then peel slowly the paper downward from under the decal,Slowly to allow the 'cal' to go flat onto the paint.be very careful not to create a winkle as you pull and apply.Use the water and card to keep the surface wrinkle free.A few air bubbles are okay,they'll come out with the card if they don't,reapply water and peel decal off,and reinstall.I also trimmed the decal around the lettering outside edges so there wouldn't be any excess clear border on there.the key here is GO SLOWLY.
1 - 8 of 8 Posts
