Gerbing's temperature controllers from Riders Discount allow you to control the temperature of your newly purchased Gerbing heated gear.
Available as either a single (MSRP $69.99) or dual zone controller (MSRP $99.99), we find most of our customers purchasing the dual zone controller even if they are only ordering one heated item. Gerbing's heated gear is so good that a lot of our customers will order an additional heated item either in the same order or soon after their original order. Adding a dual zone controller allows you to have separate temperature control of your heated garments. For example, with a dual zone, you can crank the heat in your gloves but keep the jacket liner comfortably warm. Max output is good for 135 degrees with the single or dual zone controller. A dual zone is good with a single jacket liner plus gloves, pants, and/or foot insole inserts.
Dual zone controller pictured here with the Gerbing heated jacket liner.
Not yet listed on our website, the Gerbing Portable Temperature controllers can be ordered by calling MIKE at 866.931.6644 ext. 804 or by sending us a private message through this forum. Is email more convenient? Write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
The dials are easy to use even with your big warm gloves on and have 18 indented notches that allow you to feel how much heat your dialing in our out.
Various mount options are available as well. Pictured here are the 12V portable mounts which can be attached to your belt via optional leather case. A permanent mount is also available if you would like the controllers affixed to your bike.
For any questions on these, or any other Gerbing products, feel free to contact us and our expert sales staff will help you out!
Gerbing heated jacket liner and gloves pictured here.
