1 - 20 of 153 Posts
Is it safe, for road riding, to run stage 2 sc gears with no ic? I'm doing tt3 exhaust, sprint filter and Pcr flash. Toying with the idea of adding gears as I'm a big fella and need more power to move me:)
Not sure if that means you already rode the bike reflashed? If not I'd ride the bike reflashed before then also adding SC gears. You might find it's a handful.
If I was only doing just mile events where temps don't rise like long blasts on the street I'd consider it or even if it was a circuit track bike where after each 20min session I could stop and let the bike cool down. I'd definitely go w/ an intercooler, fuel pump & proper tune though. But I put on a lot of road miles and many of those are in summer temps. & long blasts at high mph. Right now my bike runs nice & cool.
There's a long history of doing reflashes with higher rev limits, currently own 2 bikes & 1 sports car with higher than factory rev limits. You couldn't count how many reflashes have been done reliably over the years this way & the H2 is better built for it than probably any other motor but H2 SC gears are more experimental.
Besides the fact I actually can & do use more peak horsepower you get w/ 1k more rpms on high mph straights especially in the higher gears but adding more power down lower just means even more finesse w/ the throttle on turns, its already a beast. It's not like I've mastered putting down 250rwhp w/ the bike leaned over, very few in the world have so don't a need for more performance in the lower revs, even on the straights where you can put the power down w/ Stage II the front comes up till 5th gear if you snap the throttle.
The results & tech look promising but beside inlet temps without an intercooler theres also the non OEM fitment issue that I'm going to wait to be resolved. I just can't have that in my mind while riding that the lower gear could be backing out, honestly it would drive me mad. For me it's not worth the risk, others differ, that's ok, I respect the opinions & moves of some people running gears & give them props for pushing boundaries but for now because of the way I use my H2, mostly hard street riding, couple of track days & because we don't have any long term usage of gears on the H2, I'm following Brocks lead on it. Just my honest & humble opinion.
You can never have to much power. Suppose what v-max is probably thinking is get it all done at the same time. Looking at Ricky Gadsons strip down video it not to difficult. My view is in uk we don't get days that the weather is 30 degrees +. You never get chance here to,open anything up for much distance roads are shorter and busier. Can't see it causing issues of heating but it's expensive if you *uck the engine or supercharger so understand the cautious comments.
On a selfish point it would be interesting to see the figures as we know a base line of what PCR with reflashes can get. 243 bhp with T3 exhaust. 253 with T3 exhaust and filter.
To answer the Vmax's question, I don't think it's recommended to run Stage II SC gears without an intercooler. If you're drag racing and only doing a few runs and giving the bike a chance to cool down then it should be fine. If you're doing high speed highway runs for several miles then you'd be better off getting an intercooler. Riding around town makes no difference. It'd be a waste of money just to ride around town with a stage II SC gear setup.
Keep in mind that it's a very well known fact that a Flashed H2 spilled it's guts on a very fast highway run, and that was without SC gears.
I'm a big fella too, about 230lbs when I'm not training and believe me, a regular H2 with a flash is enough to shock you with a wheelie at 170mph. So, the responsible side of me wants to tell you to just enjoy the bike as is.
These things are no joke and we're waaaaaaay past the point of "Just because one can, doesn't mean he should". hahahahahahaha
Lastly, keep in mind that there are no TRUE long term tests. We're all rolling the dice when we mod these things. Even with a simple flash.
Yes, it is risky but as nick said, in the U.K. Their is nowhere you can hold this bike open mile after mile, just bursts through the gears here and there.
When I say I'm big I mean, I would bet I'm by far the heaviest h2 owner. I used to train for strength competitions (strongman etc) until I was told I had a bad lung condition so now train for leisure but when I was ready to compete I weighed just over 27 stones (350lbs) now I'm around 24 1/2 stones.
On the plus side, my mass does help to get the bike away quickly, if I lye down on the tank it hovers but goes very well. Down side is up at the speed limiter, even with my zero gravity screen, aerodynamics are an issue.
**** we got some big H2 owners here. In complete contrast to Vmax I'm bettin I'm the lightest H2 owner on the forum weighting in at 147lbs (no gear). For the last 3yrs I've been training specifically to keep my weight under 150 for power-to-weight ratio on my zx10 superbike for racing, but I'm done with that bike now and focusing on the H2. power-to-weight is off the spectrum now :eek:
I was wondering if this thread could be used for guys posting their history with their gears mod.
That way it would all be on 1 thread ...
Hey Racer172 on the track, and the street, with your setup,
Is your bike always staying cool? Thanks
Yes, so far. I've been careful not to keep it up in the high RPMs for extended periods. Usually doesn't go above 200f. At one point on the track a couple weeks ago I was out there for 20+ min. pushing hard and it climbed to 220f so I took 1 cool-down lap and boost temp came down. 230-240f is the danger zone for meltdown. I will be installing the intercooler soon.
So, I noticed, bear racing do a stage 1 gear which is a small increase in boost and just changes the top gear. Might do this with the flash, filter and exhaust for this season and then go further, if necessary, this time next year. Any thoughts/experience with bear racing products?
Not sure but be good to see results. I set the goal to beat my 153bhp at PCR racing dyno :D I know you up for the challenge.
I have a full set of wings from Bear and his communication and customer service is top notch. I don't have any gears installed, but Bear Racing manufactured the RG62 gears so the experience should be consistent.
I saw that also.... I'm thinking of doing the stage one also. I already have Dons flash and auto blipped down and my own AKR system with a ton of light weight mods including BST wheels. I'd love the stage two but I want it completely safe and don't want the added weight of the intercooler set up or the potential hassle of the lower gear bolt coming loose. Quite frankly she's more than enough now but what's a little more lol. I just picked up the new Ducati 1299S Anniversario so I'm splitting some time with her and will give me a chance to add the gear and have the map checked to be on the safe side.....
The information about rider weights is interesting. I'm around 14 stone, or 90 kilo, plus a bit when kitted up. My race leathers etc probably add another stone.
The H2 accelerates so strongly that rider weight has a lesser effect than on many other bikes. Look at it this way, if you can't get onto full throttle without it wheelying then rider weight is not a factor.
My H2 needs to be in fifth gear before I can get anywhere near wide open throttle, even then it needs care. Believe me, when doing a standing-mile top speed run and it's still trying to pick the front up at over 180 mph you have enough power.
By far the biggest limitation to a high top speed on the H2 is it's poor aerodynamics.
I have Don's flash 1 which is the early version and it still has the 13,000 rev limit. Since my bike's peak is at 12,000 it's geared accordingly. However, since I have already set the UK records for the Stock class I am considering the supercharger gears as a way to be competitive in the Modified Stock class - but I will probably need the later ecu flash and I assume it will need a lot more fuel. Does anyone know where the limit is with the standard fuel pump and injectors?
To answer your last question, I'm running the Stage II SC gears with only the lower injectors spraying more fuel with the PCV. I've had no issues with fuel starvation relating to fuel pump limitations. I used the dyno as my testing ground. I believe they say you should upgrade the fuel pump when you go stage III. I get 66-75 miles on a tank now with the Stage 2 depending on how hard I'm thrashing it. Definitely a guzzler for sure, but I've had no starvation issues.
Discussion Starter · #19 ·
How about heat? I spoke with Pierre at bear racing and he said it will be fine. What's your experience?
Heat is an issue for H2's in general.
Here are my thoughts/opinions on the Stage 1 and 2 in bullet point format:
  • Highway droning at a steady pace - Heat is not an issue
  • Track Day sessions of 15 minutes - Heat is not an issue
  • Drag Racing at the strip - Heat is not an issue
  • A Single Top Speed Run - Heat is not an issue
  • Moderate RPM Canyon runs - Heat is not an issue
  • Dyno Sessions. Bike needs to cool down periodically - Heat is an issue
  • Fast Highway runs at redline for 30+ miles - Heat is an issue
  • Hard riding in the dead of summer - Heat is an issue
This is just off the top of my head based on my personal experience. This list could obviously grow down the road.
1 - 20 of 153 Posts
