Hey guys, I almost used up all the stroke, do you think is the fork spring need heavier spring rate?
(I am 72 kg body weight only)
What is your suspension adjustment? Is preload at maximum? Compression damping? At 160 lbs, you must be the late braking king, to make that happen.
Are you sure the indicator is tight enough on the leg?
hello, spring is 10 turns in, rebound and compression 8 clicks from fully close
of course the stroke indicator is in perfect condition
