1 - 20 of 29 Posts
I strapped my gopro on to take the first ride on my new to me 2016 h2. Fastest bike I have owned prior to the h2 was my 2016 ktm superduke r. Let me know what you guys think!
I take it you like yer little H2.Hey...congrats.I added a plastic washer fitted to the throttle bar(like a garden hose washer).Snugged up the bar end.It added some friction to it,perfect for eliminating that twichy throttle.A little red loctite on the bar end threads.Let sit.Works excellent.You can find the right amount of friction then set it.Have a blast man...welcome fellow spaceship jockey!
I went to the hardware store and got a teflon washer.Thanks for the vid.Always fun to hear and see new owners and their impressions!;)
Thanks for the tip! ill have to give that a try for sure. I was also going to ride up to brocks and see if he can do anything about it. Its been so cold here i have only been able to ride the bike once.
"ride up to brocks and see if he can do anything about it."...yeah.I think so.Maybe someone here will chime in and review their Brock's setup?I haven't ridden mine without the washer since about the 3rd day of ownership.So I can't say.Meaning,I have the Powercommander and the guhl flash.I disconnected the PC though cause it seemed too rich.Doing fine with the Guhl flash.But still using the washer.Anytime I want the PC,I just connect the mains.
I will definitely try out the washer mod. Seems like an easy and cheap fix. I live about 15 min away from brocks so I was planning on seeing if he can do anything in the flash with how touchy the throttle is. My understanding is he has a second party Guhl flash them tho.
Don Guhl does the flash.EXCELLENT work for sure.Brock says he can soften the throttle up with the stage 2 package.Pretty sure he can work something out with yours.
Regarding the throttle, this is my experience with my old 2016 H2.
Derestriction was purchased via Brock’s, sent my ECU to USA to be flashed and returned derestricted & supplied with a PCV loaded with Brock’s fuel map.
Positives: Complete derestriction, great service, fast international delivery, knowledgeable/helpful staff and Brock is also an approachable and very helpful guy.
Negatives: I’m in UK and the PCV map was initially too rich for our fuel, Brock helped me with this and it was much better after uploading a new map he mailed.
However, my throttle was always shocking, whilst it’s supposed to improve the reality is that it didn’t. Power, massive, controllability, finesse, NO!
I know it’s helped some but personally I didn’t want a mechanical “fix” by dicking around with my throttle to slow down the action, no chance (on a £22k bike) am I cramming in a washer or fitting a new throttle tube.
I ended up taking it to BSD performance UK (my old bike still top of their list @250bhp)
https://bsd.uk.com/bike/kawasaki-h2/
BSD went back into the ECU and looked at the throttle map. Everything “throttle by wire” was at 100% & derestricted as per Brock’s H2 ECU flash info. It was mega aggressive from low RPM hence still remained like an an on/off switch.
I left the bike with Mark @ BSD for a week and he dropped onto it as a project in between jobs. Eventually he mapped the throttle to be much more usable in the real world (like when picking it up out of bends and having a predictable delivery rather than “all or nothing” doom switch!) He’s used this info to set up several more H2’s since.
I’m in no way being negative about Brock, as I say, great guy, great company and will absolutely purchase from them again.
However, the part done by Guhl (the actual ECU Flash) in my case, other than derestriction/massive power, didn’t help the throttle & was perhaps made worse by the PCV fuel map being initially wrong for the UK.
I hated the delivery as it had zero finesse & was so depressed I went to test a Panigale V4 (that was a massive disappointment as per my other post!)
Throttle can be genuinely improved though, my advice is let Brock check your fuel map, and then find someone to get the throttle mapped via the ECU
The throttle on my 2017 is fine, yes the slightest movement causes an instant response but its a different mind set compared to other bikes. I am so used to the H2 throttle I now find other bikes lazy.
true rick.....i found all newer bikes 2016 on were snappy and i like that! lol H2 throttle is mapped by blot graph can move power about each gear i think....it takes bitta time to tune then woolich takes minutes to upload so bit time consuming/expensive
Totally agree Rich, proper way to "calm" the throttle is through the ECU
I had mine flashed at PCR, my remit was to calm the throttle down, I wanted it controllable, but not to loose its "character". I ride my H2 pretty much like my other bikes, I prefer the bends rather than ragging it up the straight all day long
Got to say, they did a cracking job
Hi Rob, heard some really good things about PCR, I think there are only a handful of tuners in the UK that can truly set up an H2 to a decent standard.
I’ll be interested to see how much Kawasaki have improved it on the 2019, apparently it’s been sorted but will report when they finally deliver the fucka!
Rich
Rich
With the nature of the bike being forced induction, you expect an "immediate response" from the throttle, problem is, there is immediate and down right fooking silly, mine is just a bit daft now but very controllable
PCR have a good reputation on setting up the H2
As far as the abrupt throttle, before I flashed it, I used a new throttle tube to mechanically reduce the throttle action. Now that I do my own flashing with the Woolich, I replaced the stock throttle tube and dialed in the off to on throttle and it is very rideable. I had also geared it up to make it more controllable, I am going to go back to stock gearing because now I want the acceleration and I can dial back the abruptness easily. And I gained RPM from the de-restriction and that should give me enough top speed.
chipmonk....it only gets goin 10k plus great vid hope you are enjoying the bike ride safe
Ya she really screams at 12k haha. This was my first ever ride on the bike. By the end of the vid i was pulling to around 12-13k. the one pull where i went by my friend in 3rd it started lifting pretty hard at 12k so i shifted to 4th. you cant really tell in the vid but it wanted to start coming up again in 4th.
Thanks for the tips on throttle taming everyone. I think the first thing I will do is stop by brocks and see if he can give me any insight. I would like to do some back road cornering but I don't know if i can keep it tamed enough for tight stuff with how the throttle is now... or maybe i just need to get acclimated to it.
My bike is a 2015, one of the first, also running a Brock's flash. Yes the throttle is snappy, it's partly emissions control I believe, almost no fuelling when the throttle is closed. This is why it's a bit like a switch either on or off and the bit around 3,000 rpm is best avoided too.
However I've persevered and I'm now used to it and can ride the bike smoothly. The other week I left my H2 with GT Motorcycles for it's annual service and they said I could use any of their demo' fleet to go home on. The new Kawasaki's weren't available as they were being registered for 1st March but I had the pick of the other makes including all the Ducati's. Since I've ridden most of them before, including the V4, I chose a Scrambler just for the experience of something different. Ok, it's totally different from the H2 and you might think I missed the extra 200 bhp but the thing I noticed most was having to wind the throttle round so far to get any response from the engine.
When I returned the Ducati that afternoon and rode home on my H2 I realised that I actually quite like an ultra-responsive throttle.
I virtually cruise style now everywhere.I have my fun of course.But adding that washer for me was mainly for cruise control.It works great.I can ride quite a few miles without having to use my throttle hand to hold er steady.And it's totally funtional.I do have to physically roll the throttle off to slow up,but it's definitely nothing dangerous.Totally controllable.If God forbid she ever dropped while running,the down sensor would kill the motor anyway.
They set mine at "L" when I bought it. After driving it for 10 miles, I changed it to "M", and maybe after 120 miles I changed it to full power. Being new to the bike I took a somewhat conservative, in my mind, approach. I still have full traction on the bike, don't see a reason to change that right now.
1 - 20 of 29 Posts
