Try starting it at a dead stop. No movement. If that doesn't work I think it's battery. Kawi uses very small batteries and in previous bike there has been low voltage issues. I think you were rolling when you turned key however as I did it a million times on my 10r and I suspect all Kawi do this with esdGood day all. I have an H2R. Anyone have any experience with the ESD warning light. Mine started coming on at about the 350 mile mark. Thank you in advance for any feedback or comments.
Did you replace the battery or does keeping it on a battery tender keep it up to par? It doesn't usually come on until I hit approx 44 MPH.Try starting it at a dead stop. No movement. If that doesn't work I think it's battery. Kawi uses very small batteries and in previous bike there has been low voltage issues. I think you were rolling when you turned key however as I did it a million times on my 10r and I suspect all Kawi do this with esd
If you're still using the standard lead-acid battery - ditch it. I put lithium ion batteries in all my stuff now and don't even need battery tenders anymore. Plus it will shave almost 10 pounds off the bike. They're expensive but worth every penny.Try starting it at a dead stop. No movement. If that doesn't work I think it's battery. Kawi uses very small batteries and in previous bike there has been low voltage issues. I think you were rolling when you turned key however as I did it a million times on my 10r and I suspect all Kawi do this with esd
That's actually odd. By then the stator SHOULD be making enough power for lights etc so idk sometimes these bikes have issues at low rpm because they're basically drawing more vintage that the bike is creating but at 44 you should be making enough. So long as you don't instantly shift 2,3,4,5,6 by 44 I don't know what yo say.Did you replace the battery or does keeping it on a battery tender keep it up to par? It doesn't usually come on until I hit approx 44 MPH.
same hereFunny you should mention it but the ESD light came on on my bike the other day when I turned the ignition key. There was a moment while I thought "what's that?" before I realised Electronic Steering Damper.
As I knew there was nothing in the menu about it I decided to cycle the ignition. So I turned it off and on again. Problem solved.
I did that and there was no positive response. LOLHad the ESD light come on. Below is what the Owners Manual says:
*1: ESD (Electronic Steering Damper) indicator may blink and the warning indicator may go on when the ignition switch is turned on with the motorcycle moving. If this happens, first turn the ignition switch off, and then back on with the motorcycle
completely stopped. The ESD and warning indicator should then go off. If they do not, have the ESD system checked by an authorized Kawasaki dealer.
That's what IS what I didand not since
Happened to me then remembered this post. If you turn on the ignition, roll/move the bike slightly prior to starting it, think that's what causes the ESD light to come on...... Turned ignition off & back on, no ESD light.Had the ESD light come on. Below is what the Owners Manual says:
Are you sure it's not already on when you start off? What I mean is - If you turn the ignition on and then roll the bike even slightly before starting it the ESD will come on. Cycling the ignition clears it. Wasn't sure if you read the posts below or not about this.I've been getting it coming up on the H2 pretty consistently after about 20 minutes of riding. Off/On resolves temporarily, but then back on...
Haven't really been able to pin it down to anything in particular, just time frame wise seems to be approximately 20 minutes steady riding.
