So I've had huge success with running this in my cars. I know that Ricky Gadson has a H2 running it. I remember Brock saying the pump was running out Ricky's bike when he had the supercharger gears installed. I figure with josh the stage 2 the pump would be good.
Anyone have any more info on what troubles I might have. I heard there were some other problems with running but couldn't find any info on what it is.
Any info would greatly be appreciated.
It's been rather quiet since the testing done by a while back. I remember, as you said, that they had to flow much more E85 to get the power. There were some top speed runs done where, perhaps fortunately, they didn't get it onto 100% throttle and the subsequent dyno' test showed it to be very lean at the top end. Not heard anything recently.
It's been rather quiet since the testing done a while back. I remember, as you said, that they had to flow much more E85 to get the power. There were some top speed runs done where, perhaps fortunately, they didn't get it onto 100% throttle and the subsequent dyno' test showed it to be very lean at the top end. Not heard anything recently.
See this: http://www.ninjah2.org/forum/206338-post12.html
Yeah, that's the only info I could find. It seemed that the fueling problems occurred when they started tuning in the RG62 parts. Was hoping since I don't have as much airflow with just the Brocks Stage 2, there wouldn't be any issues.
There is some pump and injector test result in my LSR build thread
i think to be safeon E85 a pump upgrade and consider an injector size change on the secondarys
