1 - 3 of 3 Posts
hi, I tried to show the error codes and I followed the procedure.. 1) key on, 2)odometer displayed, I held down simultaneously the up / down but do not I see nothing! did I do something wrong? thank you
Do you have a check engine light on? If there is no check engine light currently indicating a problem then no code will show. If there is an intermittent problem, then you need the special tool computer hook-up that dealers have to check the history.
Discussion Starter #3
because I understand all is ok! thank you
1 - 3 of 3 Posts
