21 - 24 of 24 Posts
this week I will have my h2r camshaft and my vandemon, I already have the fuel pump extreme creation then I will show you the results of the dyno
I just need the intecooler, stage gears and hypedrive ... and finally I'll finish putting together the **** h2!
Interested to see how you go with the EC fuel pump. I was under the impression it was not needed if just installing the H2R cams only, unless you mean it's for when you add the stage gears etc,?
if later I'll put the gear stage 2
but before the intercooler I decided on the one that yagerWERX manufactures
with the extreme creation I can not use my rg62 velocity stacks
Did you install the cams?
21 - 24 of 24 Posts
