1 - 4 of 4 Posts
Does anyone use one with their H2?
If so, does it have any access limitations that cause issues?
I have one for mine, what do you mean by access limitations?
The only issue I found is that you have to have the kickstand up, so I took to leaning the bike against me at the track as I fitted the stand. Wound up scratching the fairing a bit on my knee puck as a result. The Bursig is great for storage in tight spaces though.
With all the mounting brackets it looks like it would be tight getting to the counter shaft sprocket area.
Do you think you would be able to swap a counter shaft sprocket while on the Bursig, or would you have to use a rear only stand?
1 - 4 of 4 Posts
