What do you guys think of this.... a little taste of kawi technology.
They didn't.Kawasaki probably engineered the boost limits in with the supercharger drive.
The only thing they could have done was put different sized sprockets on the bike the H2 has a 22T drive sprocket and a 25T drive sprocket which is a 0.88 ratio. which is a reduction in final speed.They didn't.![]()
Worse. Mechanical engineer who works with the automotive industry.Nerds.
True yes, but I'm willing to bet the street H2 would require the same look over after substantial amount of time spent under high stress application.It is interesting when you read Kawasaki's website regarding the R. They suggest an inspection after 8 hours at over 8,000 rpm and a bottom end job after 15 hours. Who are you going to trust for this work, the lawnmower guy at your local dealer????? This should be an easy $2000 to $3000 bill. I am still curious why the R needs much more maintenance than the H2? The exhaust and clutch don't cause this wear? The ECU and cam timing must have pretty aggressive specs to require this kind of attention. Can't wait to unravel all of these mysteries.
