Bell has updated their RS-1 line with all new colorways available from Riders Discount.
More on the RS-1: The Bell RS-1 is a SNELL M2010 and DOT that sits in a sweet spot, both performance and price-wise. The sleek, aggressively shaped shell is made from a Kevlar/Fiberglass composite that makes it both strong and lightweight. The RS-1’s shell cuts a profile that is similar to that of the Bell Star, which results in an excellent aerodynamic balance that keeps buffeting to a minimum. Air also flows through the helmet very well. The Velocity Flow Ventilation system is adjustable and quietly keeps your head cool.
Internally, the Bell RS-1 is a comfortable place to be. The lining and cheek pads feel very plush on the skin, right out of the box. They also break in quickly. An Agion Antibacterial treatment helps keep things fresh, but the lining is fully removable and washable in case things get a bit too sweaty. The RS-1 comes with a clear NutraFog II anti-fog/anti-scratch shield, which is the same as the Star. The ClickRelease shield mechanism is also shared, making for shield changes that can be done in seconds. Be sure to ask about adding the popular Bell Transition shield to your order as well!
If you are interested in the Bell RS-1 Servo, you can give MIKE a call at 866.931.6644 ext. 804, or contact him through this forum. Is email more convenient? Feel free to send those to FORUM at RIDERSDISCOUNT dot COM and we’ll get back to you right away!
