New from Ballistic Performance is their battery back-pack. Available from Riders Discount, the Ballistic Battery Back-Pack is a USB power supply and emergency jump start that is small, light, and can fit in the tail section of most bikes.
This is not currently listed on the website, but you can place your order with MIKE by giving him a call at 866.931.6644 ext. 804. Is email more convenient? Send us a message through this forum or write to us at FORUM at RIDERSDISCOUNT dot COM, and we'll get back to you right away!
Includes a 12V or 120V power supply to charge the back-pack itself. Also included are jumper cables and a universal USB charger cable.
A battery backup is a crucial piece of emergency equipment most of forget about. If you are ever stranded with a dead battery on your motorcycle, this can truly be a life saver. With a starting current of 200amps, and a burst current of 400amps (5 seconds at 70 deg F), this can bring virtually any bike back to life and get you back to safety.
This measures at 131mm x 75mm x 25mm at just over half a pound. It's fully charged and ready to go in 3 hours, and discharges at less than 10% per year and able to work in extreme environments from 0 deg F to 140 deg F. Four LEDs alert you to the current status of the battery.
Ballistic has also added a USB port and universal charger cord with 30-pin, micro USB, mini USB, and Lightning plugs to charge virtually all mobile devices on the market today.
A built-in LED flashlight that is bright enough to help you signal for help in the daytime or dark of night with multiple flash modes such as solid, strobe, or S.O.S.
