1 - 16 of 16 Posts
Anyone using one on their H2?
And if yes any recommendations on what to use.
Just something I'm looking into possibly getting
Not on the H2, yet
I do however have a JMT lithium Ion on my zxr750 track bike, 2kg weight saving
There is an argument as to whether you have to use a lithium ion charger, some don't and use a standard one, personally I use the proper one
Had no problems with it, turns the bike over quickly
You just have to make sure you don't let them discharge, mine has a little 3 light indicator on to see its charge state
I put in the biggest Shorai battery that will fit in the stock battery box.
These bikes appear to have more parasitic drain when switched off than most. I have to connect mine to a charger (an old cheap "dumb" charger - and keep an eye on it with a plain ordinary multimeter) for a few minutes every couple of weeks.
I have the Aliant X2P. Not Li-Ion but Li-FePO4. Way lighter and smaller than stock. I keep it manteined with a proper charger.
I have the luck that I already have a Lithium charger. Not one you can keep connected all the time like my optimate. As from what I understand you should not keep them connected for a long time. Only needs to be connected for a hour a month.
I only had a cheaper non name battery on my Blade so why i'm looking for something better for the H2
Lithium Battery
I have had a Shorai on my H2R for almost 2 years. Never a problem even when I rode it on the street. I put the Shorai charger on the other day and it was at a full charge. Other than that couple of minutes, it has never been on the charger.
yep, first thing I did was drop this in
Reactions: remal
I have the Shorai. Works perfectly, and really spins up the starter. You will want the
Shorai LFX19A4-BS12. Ducati of Omaha had the best price on it when I got it. Amazon has it for $156 shipped Prime.
When you install it your H2 stock terminals will be too small for it. they have two lips that bend down and make contact with the stock battery terminal. Just put a pliers on the corner of it, bend one tab up and it fits perfect.
Question for the guys with the Shorai Li battery. Shorai LFX19A4-BS12
How did you get the battery to fit, since the stock connector claw is smaller than the metal plate on the Shorai battery.
Did you flip the stock connector or just straighten the metal claw.
Thx
Thx
I just straightened the claw thing to make it fit.
Thx
Skipped post number 9 on THIS thread, did ya ?
Well at least you didnt start a brand new thread to ask...lol :)
1 - 16 of 16 Posts
