1 - 4 of 4 Posts
Only thing I could add to this would be a cracked head/gasket? Or some other seal failing causing antifreeze to mix with the oil? Definitely not a good sign on any engine.
Are you able to get a trusted mechanic to check it over? I'm thinking a compression/leak check, apart from obviously taking the head off, may show results. I'm sure far more experienced heads will give decent advice.
Good luck!
1 - 4 of 4 Posts
