1 - 7 of 7 Posts
Just installed the full Akra exhaust and I get a check engine light. Is that from the O2 sensors, the (disconnected) exhaust valve servo, or something else?
help.....
If the ECU has been flashed the exhaust valve servo should be disabled anyway. If there's no lambda sensor fitted to the new system I suspect it's probably that causing the error. There is a bush behind the pre-muffler to fit the sensor to the Akrapovic system.
No on the flash, no on the sensor. I'll do that now and report back.
Yep it was the O2 sensor. Light is off now. Wondering where I can get that map/flash? Is there one specific for the Akra full system?
Three options for flashing the Ecu, but you will always need to remove it from the bike:
1- Send the ECU to someone that will flash the ECU for you (Guhl/Brock)
2- Buy a DIY Flashing Kit (Woolich/FT Ecu)
3- Take the bike to a verified shop that will do all the work for you
1 - 7 of 7 Posts
