Hey Arthur.Yeah,the angle is a bit rough to ride all day.What I did was buy a new seat.Okay.Removed cover(s).Took a carving knife and cut the underside off the original.The large foam blocks that fit into the pan.I shaped that to how I wanted to be angled.Any area of the underside that had any extra foam,I removed.So it was totally one thickness.I then used the new one pad and removed the large blocks of foam.This one I cut with the carver pretty thin about half way back to the tail of the pad.So pretty much I had TWO nice thick angled pad areas up front,and a more padded rear portion.You have to kinda eyeball how you want to be sitting on there.Then put the two together and sit it on the bike and see how it feels.If ya go slow,you can get the cuts just right.BUT...do NOT cut from the top foam surface.Leave that alone.The cover will fit on there,just take your time fitting it.After several trials,I finally got this last one just right.It's WAY comfy and angled perfectly for me.
