2022 H2 SX SE will there ever be a tune available !!!!
500 Views 3 Replies 2 Participants Last post by  GRUNTMAX
I have a 22 H2 SX SE since august last year still not much out for this Bike i am considering selling it for somthing else , I wish i bought a 21 instead atleast i could find exhausts slip ons and a tune ... Im starting to get frustrated does anyone know if anything is in development , also does exhaus/slip on from an 21 H2 sx se fit the 2022. Any info would be greatly appreciated ...
1 - 4 of 4 Posts
That is easy. Just compare OEM part numbers of the different years. Most part numbers are the same.
Tune the bike yourself with the Woolich Racing Auto Tune. Ron Ayers has probably got the part numbers listed.
Next comes the Compression Ratio Drop & H2R Camshafts
Reactions: 1
2022 uses new Bosch ECU not the same as prior years !!!!
Thanks. The Bosch ECU explains your question. I noticed Ben fitted a standalone ECU in this;
Would still need a different patch harness which would throw a spanner in the works though.
You'd probably be better off writing to Woolich & they may be able to give you a timeframe when the 2022 would be ready.
1 - 4 of 4 Posts
