1 - 2 of 2 Posts
Curious if anyone with a 2021 has done a Brock’s slash 2 with only a power commander 5 map with no ecu flash.
trying to get impressions of that kind of a set up.
I’m not looking for real power gains, just a tune to make the bike run properly the pipes installed.
can anyone provide some input?
Brock’s is not doing the ECU flash any longer they used to do it after Guhl had to stop now you can reach out to Moore Mafia he is legit and a great person
He will be able to flash it for yah
If you don’t want to flash then I would just change exhaust to full and switch out filter run it and see the ratios if it’s too lean or not but might as well flash it
1 - 2 of 2 Posts
