1 - 12 of 12 Posts
Guys I have a 2015 H2 that’s got the Guhl flash, full exhaust, stage two gears, volicity stacks, BMC filter and some BST rims. I’m looking to see if anyone has added the 2016 lighter pull clutch to the 2015 or a larger slave cylinder for an lighter clutch pull and still have no slippage? I’ve gotten spoiled with some of my other ladies and want to see if I can find a lighter pull set up that works well.
Kawasaki do make a complete clutch replacement pack to upgrade(lessen) the lever pressure to that of the later models.
I have a brand new one sitting in the shed!
Discussion Starter #3
Interested in sell it? >:D
Reactions: enzo200500
The update kit is not all that expensive
conversation somewhere on the forum about it , going back a couple of years
I have the 2016 clutch fitted to my 2015 H2 , it has no problems with slip and is super light but my bike is standard/stock .
Discussion Starter #7
I'll have to see if I can find the thread. My girl put down 255RWP will the 2016 clutch hold that much? or will I need to add the brocks springs?
2016 clutch has lockup ramps , so the more load you give it the more it adds pressure to the pack,
you would have to try it for yourself, i wouldnt have thought you would need heavier springs at that level, until i saw Richards clutch problems
bet even with the heavier springs the clutch is much lighter than the 2015
Discussion Starter #9
Ok thanks OZ!
Discussion Starter #11
Wasn't the slipper clutch introduced in 2017?
I had thought they all had the slipper clutch? If not maybe I can go with the 2017 and get both the lighter lever pull and a slipper :D
1 - 12 of 12 Posts
